I have the task to evaluate magnitude, phase of E-field as well as angular and delay variance of it after transmission through highly-dispersive media (see image as attached). Particle size - 50um - 2mm and density of the particles is variable. Shape of the particles is sphere or cube. Materials are water, quartz, organics ets. Distance between Tx-Rx is 0.1 - 1m. Antennas are horns with HPBW = 10-20 degs. Freq is more than 10GHz. What would be the best computational methods for modeling of the task? What would be the best way to built geometry of the task?
Thank you.
BR, Dimon
