I am looking to constrain a hole of a 3D model. I am currently using RBE2s (with all 6 DOFs on) within the hole and applying a constraint to the independent node in all 6 DOFs.
Doing this I am able to successfully run the optimisation.
However, I want to simulate a bar constraint where the model can rotate about the y axis but no others. I have tried deselecting the 5th DOF on both the RBE2s and constraint but this results in the optimisation failing.
How do I go about applying constraints to all DOFs but 5 (moment around the y-axis)?
Additionally, I am using RBE2s currently as I can apply a constraint to these. However, ideally I would be using RBE3s as these will better represent my problem. Is this possible to set up with the constraint in limited DOFs in mind?
Thank you
