I want to capture video of simulation. I used hyperview video capture commands. But the video is too fast. How to capture it in slow motion?
I guess you could use the following…
I guess you could use the following… <?xml version="1.0" encoding="UTF-8"?>
Hello Rahul,
Thanks....My problem is resolved with your suggestion.
Hello Rahul, Thanks....My problem is resolved with your suggestion.
Hi Sir I tried the same. But still my problem is not solved. The video is making but of 0 seconds.
