It looks like you are having problems with Intel denoiser.As a test you may try turning the denoiser off and saving the image. It should save the file.
As a solution I would suggest the reinstallation of the plugin.There seems to be something missing/corrupted/blockedso reinstalling the plugin should fix.
Antonio
