Memory error in thermal simulation
User: "Iñigo Izaguirre"
Altair Community Member
Updated by Iñigo Izaguirre
I am simulating a three phase power transformer of 220KVA and when I want to do the thermal simulation of it. It appears me a memory error but I dont understand why this happens because I had done a correct electromagnetic simulation before and I dont think the mesh is very heavy. Maybe there is something wrong defined in the thermal simulation. I put here my model if you can prove it and see if you have the same problem and how I can fix it.
To do this thermal simulation I have removed the infinite box. After that I have defined the power losses in the volume region and the thermal exchanges with the environment as face region in all the faces of the model.
Thank you,
Iñigo
1 - 1 of 11
    User: "fzidat"
    Accepted Answer
    Updated by fzidat
    Hello Inigo;
    If it is only a thermal application, yes you can decrease the mesh, however, if there are eddy current somewhere in you transformer, they are actually a hit source, so may be it is better to take them into account.
    The losses soulde be given for the displayed part of the transformer, if you display half of the coil for instance, you should use halve of the coil losses.
    For the boudary conditions, please have a look on the litterature, but the best way in this case, is to compute them thanks to a fluidic software like Altair AcuSolve (Introduction to AcuSolve (altair.com)).
    Best regards
