I am doing a core inductance model in flux. I have done this model with non-meshed coils but I want to try to use the meshed coils in order to get the additional losses of the coil due to proximity and skin effect. Each coil of the UI inductance model has 17 turns of 0.8*190 aluminium band. I have define the coil the way you can see in the pictures.
I would like to know if you see something wrong in the coil properties and also I would like to know how would be the proper way to use meshed coils in flux. I dont understand very well how should I put the terminals and the orientation of the third picture. I put the model attached if you want to take look of how I have defined all and if you see any mistake, I would be very grateful.
Thank you,
Iñigo Izaguirre
