Altair RISE
Nominate Yourself Now!
How to set the circuit to simulate an inductance
User: "Iñigo Izaguirre"
Altair Community Member
Updated by Iñigo Izaguirre
I have a model of an UI inductance and I dont know how to set up the circuit to put all the current harmonics the inductor will suffer.The first thing I thought is to put different current sources and change the frequency of the current sources, putting them in parallel and connected with the two series coil. I am not able to follow my idea because I dont know how I can change the frequency of each current source. Furthermore, I would like to put DC current source as one of the harmonic. What would you do?
I would put the model attached if you want to take look.
Thank you,
Iñigo Izaguirre
1 - 1 of 11
    User: "asoualmi"
    Accepted Answer
    Updated by asoualmi
    Thank you for your help. How would you do the simulation in transient application?
    In Transient application, there is two ways to do it:
    • You can create for each harmonic a current source and you put all the current source in parallel. Each harmonic is defined by a formal (for example harmonic N)1, I_1(t)=i_1*sqrt(2)*sin(2*pi()*f_1*t), I_5(t)=i_5*sqrt(2)*sin(2*pi()*f_5*t)) you do the same thing for all harmonics
    • You can use one current source and in the current source you define the current using I/O parameter
      • I_T= I_1(t)+ I_5(t)+ I_7(t) I_11(t)+….
    For the frequency you can use also I/O parameter for each value
    Thanks.
