I dont know how to open the next example
I want to open this project
I build the Flux Project for version 2021 using the PyFlux command lines from the phyton log file, persistent/Jython_log/Project_PyFlux_Log_1 where are saved the PyFlux command lines for all the operations made by Lavanya Vadamodala in your initial project on Thu Jan 06, from line 61.(without the solve lines)
I attach the new project for Flux2021.
Best regards,
Alexandru
It is not possible to open newer version Flux projects in older versions.
And what can I do?
For what version of Flux do you have your licence?
Is the 2021 version.
student version
I build the Flux Project for version 2021 using the PyFlux command lines from the phyton log file, persistent/Jython_log/Project_PyFlux_Log_1 where are saved the PyFlux command lines for all the operations made by Lavanya Vadamodala in your initial project on Thu Jan 06, from line 61.(without the solve lines) I attach the new project for Flux2021. Best regards, Alexandru
Thank you!!
