I have the following problem:
I have a bracket that consist of two parts that are jointed with 3 screws with anchor nuts. The loads are will be transported from the one part through the screws to the other part.
When i run an optimization(only sliding) everything works. But if I run it with "sliding with separation" it tells me that the safety factor is violated.
If the safety factor is violated doesn´t it mean, that the prepart already can´t hold?
If I run an analyis on the prepart with "sliding with separation" the parts safety factor is good.
So how can I see where exactly the safety factor is violated?
