Hi Vanessa,The following should do what you need. The Table Export from the Classic Model will not start until all the "actions" leading into it have completed. The file path from the Data Prep Export must match the input to the Classic model.Note the difference between the solid and dotted lines. The dotted lines can almost be considered "properties" of the icons they feed. So the Workspace is a property of the Data Prep Export and the input file and model are properties of the Classic export.The workflow is shown by the solid line. The first "action" is the Data Prep export. Once that is complete, the next action is the Table Export.Regards,Steve. ------------------------------Steve CaielsProfessional ServicesAltair-------------------------------------------------------------------------Original Message:Sent: 10-24-2019 09:53 AMFrom: Vanessa TannerSubject: Monarch ServerHello All,Looking for a way that I can bring in some data to date prep studios, then input the export into the classic model this way I can have filtered exports on the server. Do I have to set up a two part process? One that imports the data, manipulates it and exports out (Data Prep). Then another automation piece that ingest that export into the classic model to export the filter value summaries? I am having difficulty getting it out of data prep and into the model under the visual process on the server in one piece.------------------------------Vanessa TannerManager Optimization ServicesGap Inc Store LabsSan Francisco NM(505) 462-0455------------------------------"
Hello Steve,Thank you for your reply I tried to set it up this way however now I am facing the following error I get to about 92% of the table export then this appears.Export failed. No value given for one or more required parameters. Datawatch.Common.Exceptions.DatawatchSdkException: Export failed at DynamicModule.ns.Wrapped_IItemExecutor_39d4340fb0d14de5bb6785758179edd1.Execute(ExecutableItem executableItem) at Datawatch.Services.DataPump.Processing.ProcessDesignerServices.NodeExecutors.CommonNodeExecutor.Execute(ExecutionNode executableItem) at Datawatch.Services.DataPump.Processing.ProcessDesignerServices.NodeExecutors.NodeExecutionManager.Execute(ExecutionNode executionNode, IUnityContainer container) at Datawatch.Services.DataPump.Processing.ProcessDesignerServices.NodeExecutors.NodeExecutionManager.ExecuteNode(ExecutionNode node, IUnityContainer container, ConcurrentBag`1 stopNodes) Do you know what would be causing this?------------------------------Vanessa TannerManager Optimization ServicesGap Inc Store LabsSan Francisco NM(505) 462-0455-------------------------------------------------------------------------Original Message:Sent: 10-29-2019 10:35 AMFrom: Steve CaielsSubject: Monarch ServerHi Vanessa,The following should do what you need. The Table Export from the Classic Model will not start until all the "actions" leading into it have completed. The file path from the Data Prep Export must match the input to the Classic model.Note the difference between the solid and dotted lines. The dotted lines can almost be considered "properties" of the icons they feed. So the Workspace is a property of the Data Prep Export and the input file and model are properties of the Classic export.The workflow is shown by the solid line. The first "action" is the Data Prep export. Once that is complete, the next action is the Table Export.Regards,Steve.------------------------------Steve CaielsProfessional ServicesAltair------------------------------Original Message:Sent: 10-24-2019 09:53 AMFrom: Vanessa TannerSubject: Monarch ServerHello All,Looking for a way that I can bring in some data to date prep studios, then input the export into the classic model this way I can have filtered exports on the server. Do I have to set up a two part process? One that imports the data, manipulates it and exports out (Data Prep). Then another automation piece that ingest that export into the classic model to export the filter value summaries? I am having difficulty getting it out of data prep and into the model under the visual process on the server in one piece.------------------------------Vanessa TannerManager Optimization ServicesGap Inc Store LabsSan Francisco NM(505) 462-0455------------------------------"
