Can you please tell me the option/procedure to compare two models results and do a exceedance check (stress, spcforces) between two models in hyperview?
It will be appreciate if you can provide a tutorial on it.
Kandiyal
Hi kandiyal
There is no particular step in HV like that. You have the option to split window. you can split the window > load 2 different results in 2 windows and compare
