How to create Max stress Graph?
Dear all.
i am new to this forum. Now i am working as a NVH engineer (fresher).
i am using Nastran solver to conduct vibration analysis.
Myquestion:
In frequency response analysis. i usually apply 0hz to 250 hz to the structure and i measure the maximum vonmises stress at each frequency.
so is there anyway to plot a graph or track the maximum von mises stress at each frequency.
P.S.:
1. live tracking the stress at a same node is easy. (but it will give the stress value at that node for different frequencies.)
-> BUT I WANT THE GRAPH like
Example:
at 1hz - the max stress is 2 Mpa.
at 2hz - the max stress is 5 MPa.
at 3hz- the max stress is 10Mpa.
at 250 - the max stress is -- Mpa.
like that
( irrespective of the position , i need only the max stress)
is there anyway to plot or track the max stress. please share it with me.
(if anyone cant understand my question. please let me know. i will try to explain better or i will give you the input and output files.)
thank you.
anticipating for the answer.
You can try with the Advanced Query (Query>Advanced Query) option in HyperView, where you can extract the stress for each frequency and you can export the same.
This option is available after you apply a contour plot to your model.
0 -
thanks a lot for your answer . Mr. Geroge P johnson.
