Hello
I design a patch array antenna with feed network. Attached its design file.
As a feed network should match the input to 50 ohms, I am looking for a way to measure the feed network impedance at various points in order to verify that the feed network design has been properly performed.
Is there a way to extract the lines impedances using FEKO between various points in the feed network?
Thanks.
