Hello
i would like to construct a strip line element as drawn in the attached file.
How can I do it in CADFEKO?
I need it to be constructed in FEKO since its dimensions (R1, R2, X) should be parametric.
Thanks.
Two methods come to mind.
1) You can create two elliptic arcs of radii R1 and R2 and loft them.
2) Create elliptic arc of radius R2. Create a line of length r2-r1 and path sweep it on the elliptic arc.
