Is there any way to continue the session on other device?
Hello everybody!
I would like to ask if it is possible to fix the result file in the hyperview session, so that there are no errors if opened on another device.
Let me explain, when I open the session it does not find the reference directory so the message log reports me "unable to load" and "file not found".
Therefore, I was wondering if there was a way to fix the model and the results files in an absolute way to be able to send the session to another user, who can thus continue the hyperview session, already created, without having to redo everything.
Thank you very much!
Best Regards
Flaminia
You either need to have the result and model file in the same directory as the session file.
Or change the path in the session file to a location that contains the model and results file and that the other user can access.
1 -
All the other user needs are the results/model/session in the same directory and have the path look like this:
1 -
Jason Craanen_20442 said:
Thank you so much Jason!
