I am traying to run de virtual wind tunnel and it gives me this error: "can't perform mesh intersection between the body and tunnel"
why? what is the problem?
can you share some pictures? it migh help people from the community to better understand your issue.
can you double check if there's nothing wrong with the geometry/mesh of your part?
can you share some pictures? it migh help people from the community to better understand your issue. can you double check if there's nothing wrong with the geometry/mesh of your part?
yes, that is the problem
