I have a simulation setup which is just a simple case of particle accumulation on a flat plate. I'd like to know 2 things:
1. The correct method to measure the height of particle accumulation at multiple points, I'm asking you this question because whenever I try to measure the height of accumulation, the particle to geometry distance is a slant line as shown in the figure, I just need to measure the correct perpendicular height.
2. Is there a way to measure the average accumulation height for the entire surface?
Thanks,
Kiran
