I'm using the one way coupling using the API. I'm trying to simulate the fluid particle interaction for low density particles falling from a height (Fluid media is air), the problem here is the force field generated does not account for enough forces on particles at even high velocities (80m/s), is there an alyternate method/ formulation for Ftotal that I can use in the API for low density particles?
Thanks,
Kiran
