Can we use Excel file from HyperStudy that contains response surface calculated by HyperStudy?
That Excel (.xlsx) file contains functions and/or macros that fetch input values from some “input” fields in the sheet and write a result (value of response) to an “output” field. Are there any ways in Activate, just like LookupTable block, that writes values (from input ports) to input fields on the sheet, get calculated values from output fields and then the output them through output ports?
Minoru Yubuchi
