I have created the whole two-wheeler model in motion view. Included all joints and Motions. But showing an error after checking the Model at the end. Please guide with the same. Error pic attached herewith.
Hello Harsh
The error seems to suggest that there is some erroneous data entered for Point 0 and Point 26.
This is just a guess looking at this message. It looks like the value for Point 0 -x has been entered as X, which does not evaluate to a real value. Similarly for other point coordinates.
Also likely that a body reference (Body 1) for a joint (is it named "fork and shock left inline joint_1" ?) is unresolved.
Kindly review the points and the joints and see if you can fix these inputs.
In case you have further difficulty, kindly share the model. Someone in the forum would be able to assist you further.
Regards
praful
