I also noticed another bug on the signs, when I export the csv of the efforts at the level of the connections, the signs on the CSV file and on SIMSOLID are not the same:
So, where is the truth?Sincerely
In this particular case, it displays loads applied on the connection in the UI and loads applied by the connections (reactions) in the CSV file. They are equal and opposite. This is made consistent in V2024.1.
