Hello, I'm new here, I would like to create an own rotor design. Is there an instruction how to create an own individual rotor?
Hello,Attached is a video explaining the steps to follow to create your own room in FLuxMotor. Be careful, the time will not be set in FLuxMotor.Thank you.
Hello thanks for the video. I think that is what I need. The only one problem is , that the surface in the video of the Flux are not the same as I use. For example the button " Extensions" is not existing. Do you have an idea where the problem is ?
