In Hypermesh2021 (and older) there is a "tool > numbers" panel that I use to show f.e. node ID's. These node ID labels continue to be visible and only disappear when the "all off" option is used. How does this work in Hypermesh 2022.2?
in newer version of HW, you can select the entities (elems, nodes, ...) and use 'Q' to turn on IDs.
In 2022.3 it was changed to 'Ctrl+Q'
Additionally, you can make it visible from the drop-down menu with RMB after selection.
