I am facing issue in using hyperworks license. It is showing error code 9 license not found and asking for License server (host ID). How should i activate my license ? it is showing error as below: I even pasted license file in "C:\Program Files\Altair\2022-edu\security\altair_lic.dat".
License Log shows following error:
[04/25/24 19:31:23] System Error: No Auth Token in HHWU Config
[04/25/24 19:31:29] Error during authorizing: Could not connect to server
[04/25/24 19:31:29] System Error: SOAP 1.1 fault SOAP-ENV:Server [no subcode]
"Timeout"
Detail: connect failed in tcp_connect()
[04/25/24 19:31:29] No auth token found in config files
[04/25/24 19:31:29] System Error: No Auth Token in HHWU Config
[04/25/24 19:28:53] Activating features...
[04/25/24 19:28:53] Trying to activate...
[04/25/24 19:28:53] Deactivating features...
[04/25/24 19:28:53] Activating...
[04/25/24 19:28:53] Activating required features
[04/25/24 19:28:53] System Error during checking out: Altair License Manager: License error
Feature(s): GlobalZoneAP, HyperWorks, HWHyperMesh
Error Code: 9
Error Description:
Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
[LOCAL] C:\Program Files\Altair\2022-edu\security\altair_lic.dat - (Err: 9) Feature not found
License Path: C:/Program Files/Altair/2022-edu/security/altair_lic.dat;C:/Program Files/Altair/2022-edu/hwdesktop/../security/altair_lic.dat;localhost;C:\Program Files\Altair\2022-edu\security\altair_lic.dat;
Feature(s): GlobalZoneAP, HyperworksEDU
Error Code: 9
Error Description:
Feature not found
Feature: HyperworksEDU
Error Code: 9
Error Description:
[04/25/24 19:28:53] Unable to activate
[04/25/24 19:31:29] Releasing features...
[04/25/24 19:31:29] Invalid state for releasing
[04/25/24 19:31:29] Failed to release
[04/25/24 19:31:29] Trying activate features...
[04/25/24 19:31:29] Trying to activate...
[04/25/24 19:31:29] Deactivating features...
[04/25/24 19:31:29] Activating...
[04/25/24 19:31:29] Activating required features
[04/25/24 19:31:29] System Error during checking out: Altair License Manager: License error
Error Code: 9
Error Description:
Feature not found
Feature: HyperMesh
Error Code: 9
Error Description:
License Path: C:/Program Files/Altair/2022-edu/security/altair_lic.dat;C:/Program Files/Altair/2022-edu/hwdesktop/../security/altair_lic.dat;LNT66-OJJZD-XNDYX-S25U1;C:\Program Files\Altair\2022-edu\security\altair_lic.dat;
Error Code: 9
Error Description:
Feature not found
Error Code: 9
Error Description:
[04/25/24 19:31:29] Failed to activate
Kindly help.
