Can anyone support for Abaqus Steady State Dynamic analysis tutorial for Hypermesh used as Pre-processing tool.?
Or Anyone can support Steady State Dynamic analysis tutorial for Altair softwares?
Thank You,
Uday Pal
Hi
in the HyperMesh help documentation, there is not tutorial specific to this type of analysis.
but there are few related to setting abaqus model .
Link below point to the list:
https://2020.help.altair.com/2020.1/hwdesktop/hm/topics/tutorials/hm/abaqus_c.htm
You can set the *Steady State Dynamics card on the HyperMesh Abaqus UI thru the creation of Step and
selecting the analysis procedure in the Entity Editor:
Also, From the *Steady State Dynamics keyword description, it is related to frequency response analysis (FRA).
You can set FRA analysis that in Altair OptiStruct solver.
Please refer to the Optistruct tutorial: OS-T: 1300 Direct Frequency Response Analysis of a Flat Plate
You can find it thru the link below:
https://2020.help.altair.com/2020.1/hwsolvers/os/topics/solvers/os/direct_freq_response_flat_plate_r.htm#direct_freq_response_flat_plate_r
Hope this helps.
Regards
