I have a file with data in JSON format that is an output from a Dataprep Studio workspace. I would like to combine this output into a single field which would eventually be appended with another file that is being ingested into a database table. Here is an example of the JSON file:
[ { "Field1": "1", "Field2": "2", }, { "Field1": "1", "Field2": "2", } ]
Here is an example of the final format that would be loaded to a database table:
| Field1 | Field2 | JsonOutput | Field4 |
| Some value | 2 | [ { "Field1": "1", "Field2": "2", }, { "Field1": "1", "Field2": "2", } ] | Some Value |
Is there any way out of the box I can combine the JSON file into a essentially a single field?
Thanks!
