When running meshing / calculation, etc., Is there any log file created and running in the background? If yes, where it is?
If not, Is there a way to make it?
Hi Uri,
Inside the project folder you'll find different files (meshing files, geometry files, solver files...)
Is there any file in particular you are interested in?
I attached a document that explains how to run C2C in batch mode.
Best Regards
Thanks
