I'm trying to run a co-simulation similar to This tutorial of Stephen Cole, however I've run into a problem.
In my Adams simulation, a weight is connected to a winch with a cable, and with rotating the winch, the weight is lowered:
In my EDEM simulation, I would like to connect the weight to a geometry, and lower this geometry onto the particle bed using the Adams Co-Simulation-Interface (ACSI). However, when I run the EDEM model using the ACSI, only rotation of the geometry takes place, and no translation:
It somehow seems that the local coordinate system of the weight in Adams, is connected with the global coordinate system of the simulation in EDEM. Do you know any way / directions to fix this?
Greetings, GertJan
EDIT: after some more thorough analysis, there is translation of the object, however still 2 problems are present:
- After the first timestep the Center of Mass of the geometry merges with the global Center of Mass
- Translation goes veeeeery slow, like few milimeters after 20 seconds
