I can't install hw 11 on windows 8. I get java error at the beginning of the installation. How can i install it?
Windows 8 is currently not supported. The software (HyperWorks) would probably run on Win8, but due to the currently used installer you won't be able to install HyperWorks on Windows8. A workaround (without guarantee and support) could be to install HyperWorks on Win7 and copy the files afterwards to Windows8.
Thank you very much.
Does that worked HYDROHYPER?
You need to set up the correct graphics cards car owner for your cards. You need the graphics cards car owner for integrated graphics cards.Which set is the best for the install the window 8??
Can any one tell procedure to put the hypermesh 11 files into windows 8 from windows 7, paricularly i dont know about graphics card name changing in windows 8.
i am facing problem while installation of hypermesh software on my windows 8 machine can anybody suggest solution?
Maybe you have to wait until the next release of Hyperworks to work with Windows 8.
