Aloha Activate aficionados ,
I am wondering if there is a method (e.g., a command I can execute in the Finalization script) that will auto fit all of the scopes in my model.
In the model I have, I end the simulation with an "End" block based on a condition detected (e.g, controller is able to meet the desired setpoint within an error tolerance), which typically means the simulation ends before the final time set in the Solver Settings dialog, and so the final time is used as the scope end and the scope may show a lot of empty space and compact the data I want to view. Instead of clicking each scope to auto fit, I wonder if I can do this with a command I can execute in the Finalization or something similar. Does anything exist for this purpose?
Thanks,
Andy
