Hi everyone,
I am writing an OML script in Activate to do some parameter studies by calling vssRunSimulation().
vssRunSimulation can set parameters in the the Model/Diagram Context per the docs, but I need to set the parameters in the Model Initialization which is called prior to this because I also need to set solver parameters based on the parameters I'm changing and I believe I can only set solver settings based on parameters in the Model Initialization. Is it possible to write to Model Initialization programmatically, either through vssRunSimulation() or another way?
Thanks,
Andy
