I want to fill a complex cavity,how can I get it?
jay liu
jay liu New Altair Community Member
edited 2023 09 in Community Q&A
I need to fill a complex cavity(that's a cylinder with a complex internal structure) with particles, but if I use the particle factory, that's so slow and I cannot be sure the particle fills well, I see a method in web that is called quick filled, how can I do it? or is there another way to do it?
  • Stefan Pantaleev_21979
    edited 2023 09
    Hi Jay,
    Thank you for getting in touch with this query.
    You can use EDEMs volume packing feature to efficiently fill a closed volume with particles to a specified solid fraction and while enforcing the defined particle size distribution.
    Best regards,
    Stefan
  • Cesar Barreto
    Cesar Barreto
    edited 2023 09
    Hi Jay,
    If you need further information, we have an EDEM eLearning lesson that explains about this capability and how can be used to quickly create complex material profiles.
    Check lesson 12: Course: Introduction to EDEM eLearning (altair.com)
    Cesar
