Hello.
The attached file simulated with constant auto level point.
Filling calculation time was 38 hours for constant auto level point vs only 4.5 hours for 28sec filling time.
Is this big difference calculation time normal?
Hi Uri,
Yes the calculation time is too long, if the machine is of low configuration or if parallel processing are running it takes time.
The machine is:
Is it enough??
This is sufficient for the run.
