Dear all,
I am simulating a loaded four pole induction machine using a voltage-driven (sinusoidal) transient 2D simulation in FLUX.
When I check the B field in the stator iron (using a sensor), its frequency spectrum contains the fundamental supply frequency, e.g., 50 Hz, + harmonics due to slotting effect. In the rotor iron, I would expect the B field to vary at the slip frequency + harmonics. However, the spectrum of the B field in the rotor iron, calculated using a sensor, contains a fundamental component of 24 Hz + harmonics. So, it seems that the B field in the rotor iron is computed and therefore displayed in the stator reference frame.
The rotor currents instead have a fundamental component which varies at the slip frequency (that's of course correct).
Is there any possibility overcome this issue? maybe defining the rotating mechanical set in another way? To setup the simulation, I followed the examples provided with the software.
Thank you in advance for your help and support,
Marco
