Renumber nodes by distance
Seçkin13
Seçkin13 Altair Community Member
Hi all
I would like number selected nodes by distance according to a node or coordinate system.
I thought creating a list from createmarkpanel. Then by using hm_measureshortestdistance, i tried to get the closest node and renumber it.
After numbering i removed the node from list . In for loop i supposed it will be ok.
However i missing something.
I am looking for your help
Regards
 *createlistpanel nodes 1 set nodelist [hm_getlist nodes 1] set nodelist_num [llength $nodelist]  puts $nodelist_num  for {set i 1} {$i<=$nodelist_num} {incr i} { *createmark nodes 1 $nodelist  set closenode [hm_measureshortestdistance2 120 120 550  nodes 1 0 0] set cnode [lindex $closenode 4] *createmark nodes 1 $cnode *renumbersolverid nodes 1 [expr $i+52300000] 1 0 0 0 0 0 regsub $cnode $nodelist '' nodelist  set nodelist_num [llength $nodelist]  puts $nodelist_num  *clearmark nodes 1   }
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited September 2020
    Note: if you have 500 nodes and you want to renumber them from 100 to 600, it's better firstly renumber all to outside of [100,600], for example [10000,10500]. After that you can use script to get numbering inside [100,600]
  • Seçkin13
    Thank you Nguyun
    You are right, I always renumber with big numbers than use script
    In my code however hm_measureshortestdistance not working properly.
  • Seçkin13
    Sorry all i found my mistake.I had to use {*} sign before marking list.
    {*}$nodelist
