I want to join two perpendicular surfaces, each one have a diferent laminate, and I don't know how to do it. I need to use contact surfaces (freeze, stick..)? Rigid elements (RBE2, RBE3)? Welds?
Each surface correspond to a carbon fiber laminate and it would be built as a single piece of carbon fiber. The only thing that it would be diferent between the two laminates (surfaces) is the number of plies.
The two sufaces have a diferent mesh to creat the diferent laminates.
Thanks
