Helo,
While using Feko solver, i am getting this error. What does this means?
Hello @SUG
Please see this comment:
Kind regards
Madelé
Thank you very much for your response. In my case, i am simulating helix coil and circular coil. I can not use edge port in this configuration. It is working fine with diameter of 2.5 cm. But when i change radius of transmitter coil to 2 cm. It gives me the following error ' Error 16498: The following segments' radii are too large'.
Hi @SUG,
FEKO assumes wires to be thin. This means that a segment (= mesh part of a wire) should not be shorter than 5 times the radius of the wire. Else using cylinders is recommended. Looking at your screenshot, you should clearly model the coil as a cylinder. The attached model shows the idea.
