Even though I run Local Sequential, instead of waiting for 1st calculation to finish and then starting 2nd one, I get an error.
please advise.
Hi Uri,
Make sure that you have connected to VPN, if it is disconnected, you will get the error , but in local sequential error, the second run starts only after the first run finish, we checked this from our side, it is working fine. Moreover you can also delete the (.altair file) and restart the run.
Regards
Sourav
Thanks Sourav
'Connected By VPN'
1. What address and how to connect by VPN?
2. Can I run in parallel locally?
1. As your machine need to configure with the VPN,and number of runs depends upon license unit, if you have 30 units, it support for only one run, for the other run it will give license error.
2. Yes you can run parallel locally.
