Hi all,
i have a simulation approach where i change the particle diameter using the scale function. It works as expected but i need to adjust also the particle density during simulation to conserve the overall mass in my system. The change in diameter is not huge, so i can maintain a usuable Rayleigh time step when changing the density a priori. I see now, that is not custom to change the density during simulation, since the properties are stored in .h5 files. Is there any work-around / tipp to change density according to particle scale?
Thank you!
