associating nodes to solids?
I need to associate the nodes of the inner box mesh to the outer solid so when I mesh the outer solid, it follows the mesh of the inside part. The associating tab only let me select the solids one by one. i was wondering if I can select all the elements of inner box mesh and associate them to each solid? or I have to select only the nodes that are in touch with the solid to associate them. I mean what will happen if I try to associate a node that is not in touch with a solid to that solid?
thanks
`Hi,
What is your end objective? Do you want to mesh the remaining vacant portion with hex mesh?
Regards
Rahul R
0 -
Altair Forum User said:
`Hi,
Regards
Rahul R
Sort of. The outer box is not mappable and it has to connect the fine mesh of inner box to a coarse mesh. So I think the best option is tetrameshing.
Thanks,
