When I go to the 'View' menu, the 'Assembly Browser' choice is grayed out. I cannot select it and enable the 'Assembly Browser.' Screen shot is attached.
Why can't I open the 'Assembly Browser?'
Thank you.
Phil
Hi Phil,
The assembly browser opens only in Engineering Solutions application.
George,
Thank you very much.
Knowing that, I can continue to ignore it. (Which I suppose should have been obvious.)
Again, thank you.
