Hello All,
I'm a FLUX user, I'd like to use the CREATE_PWM macro, does anyone have any experience with it?
Thanks in Advance.
Best regards.
Carlos
Hello Carlos,If you need information to set the input of the macro, I suggest you to have a look at the directory of the macro create_PWM.pfm, you will find on this directory a Flux project ready to solve with the PWM set and a PDF file explaining how to set the input of the macro .if you install Flux in the default directory (C:\Program Files\Altair) the macro and the documents will be located in the folderC:\Program Files\Altair\2021.1\flux\Extensions\Macros\Create_PWM.PFMFor information it is also possible in Flux to imposed directly current obtained by measurment using tabulated parameters find below a link to the Article How to create tabulated parameter in FLUX to imposed measured currents in sources
I hope this helps.Best regardsCyril
