Getting an error (being kicked out the software)
Hi, My name is Shana, and I am using the Altair Feko student version for the first time. When I open the application and try to create a geometry, I encounter the attached error. Could you please take a moment to help me identify and resolve this issue? I appreciate your support and look forward to your response. Thank you so much. Best regards,
Shana
cadfeko 9338
\gitlab-runner-root\0\src\ui\libraries\domainentities\include\domainentities/Child.hpp (30): "m_pDomainEntity": Assertion failed: Did not instantiate child Wires of type altair::feko::parametricmodeler::WireCollection
00007FFD55A2D175 (ui_parametricmodeler): (filename not available): altair::feko::domainentities::Child<altair::feko::parametricmodeler::WireCollection>::operator()
00007FFD55738E7B (ui_parametricmodeler): (filename not available): altair::feko::parametricmodeler::Geometry::getTopologyEntities
00007FFD61DE103C (ui_cadfeko_application): (filename not available): altair::feko::cadfeko::SimulationMeshXtStyleRenderer::getTopologyFromNonRootGeometry
00007FFD61DDE2C0 (ui_cadfeko_application): (filename not available): altair::feko::cadfeko::SimulationMeshXtStyleRenderer::calculateSelectedEntitiesAndSubEntities
00007FFD61D4E5BD (ui_cadfeko_application): (filename not available): altair::feko::cadfeko::ModelDecompositionXtDataRenderer::~ModelDecompositionXtDataRenderer
00007FFD61D7144C (ui_cadfeko_application): (filename not available): altair::feko::values::ModifiableValue<enum altair::feko::cadfeko::LabelFilterOptionEnum>::operator=
If you are not using the latest version with all the updates, I would recommend doing so first. If the crash happens even with the latest version, try creating the geometry in an alternate way (there are multiple ways to create the same geometry). Also, try saving the model frequently to avoid losing the work done so far.
