I have got a problem with CPU usage when I use Feko 19.2 or 19.3 for RL-GO simulations. It does not matter how many cores I set - 40, 30, 20 or 10, the cores use about 20% of their computational power after a few seconds. The same situation appears on other workstations (with hyperthreading on and off) or different simulation models. In previous versions of FEKO everything works normally. Could you tell me what happened? Unfortunatelly, I can't send cfx file with the model.
Thank you in advance.
