I am calculating mass for some PSHELL elements with steel material properties using GUI mass calc (tried both elems/comps) ; in the meantime, I am adding up all "structural mass" column under Component View and there is a significant difference between 2 numbers. I am sure the Rho is consistent and same for all PSHELLs. Does anyone know what formula is used to calculate the mass in the GUI/Tool ?
Thanks
