How to get rid of these errors? I assign FEM for Anisotropic material.
Hello @Ranjitha Ravishankar
Feko only supports passive media, so you should review the anisotropic medium definition. Is the defined medium a passive medium? You can run CEM validate (Solve/Run tab) in CADFEKO to see which regions (and media definitions) trigger errors.
If you need further help, please add your .cfx model and/or .out file. Also, what version of Feko are you using?
Kind regards
Madelé
Hi
I did CEM validate. this is the error. Can you please help me in fixing it?
Also uploaded file.
If you attach your model file (.cfx) others could take a look at the definition of the anisotropic material in your model. From the CEM validate output, it still looks like the anisotropic material definition is not valid.
