🎉Community Raffle - Win $25
Join and Win
split a group of lines using points in the model
I have a model of lines.
I made point at the crossing location of lines using the option
and finally the model is as shown below.
Now i am trying to write a tcl program to split these lines at these points using a for loop.
the code i try to make is as below.
*createmark lines 1 "displayed";
*createmark points 1 "displayed";
set LineList [hm_getmark lines 1];
set PointList [hm_getmark points 1];
foreach LineId $LineList {
foreach PointId $PointList {
*linesplitatpoint $PointId 1;
this code has some error, Please help me to Fix this code.
Thank You
1 - 4 of 41
    QuyNguyenDaiUser: "QuyNguyenDai"
    Altair Community Member
    Updated by QuyNguyenDai
    Can not help with "some error". Could you show all error message here?
    Thank You Nguyen-Dai.
    The error message i got is as shown below.
    while executing
    "*linesplitatpoint $PointId 1"
    ("foreach" body line 2)
    invoked from within
    "foreach PointId $PointList {
    invoked from within
    "foreach LineId $LineList {
    (file "C:/Users/userid/Desktop/hypermeshmacro/linesplit.tcl" line 5)
    invoked from within
    "source {C:/Users/userid/Desktop/hypermeshmacro/linesplit.tcl}"
    ("uplevel" body line 1)
    invoked from within
    "uplevel #0 "source {$file}""
    (procedure "::HM_Framework::p_FileLoad" line 68)
    invoked from within
    "::HM_Framework::p_FileLoad 24"
    (menu invoke)
    Hi
    while checking the command tcl file, i found that *linesplitatpoint is first making a node at the point and then dividing the line at the node.
    so i modified the program and model as below.
    In the model i made nodes at the intersection of line instead of points.
    and in tcl script i used the nodeid.
    *createmark nodes 1 "displayed";
    set NodeList [hm_getmark nodes 1];
    foreach NodeId $NodeList {
    *linesplitatpoint $LineId $NodeId;
    only line 1 is split and then the program stop with the following error message.
    while executing
    "*linesplitatpoint $LineId $NodeId"
    invoked from within
    "foreach NodeId $NodeList {
    invoked from within
    invoked from within
    invoked from within
    invoked from within
    (menu invoke)
    Thank You
    Please see the sample HM file attached. Thank You
