unconnected elems when adjusting normal
Hi
I encounter an error said ' some elems appear to be unconnected and were not processed' while adjusting normals
Is there anyway to fast find out those elements?
some small number of elements then I can find easy but it's huge
Kindly note that my model is OK about quality, free edge, connectivity/duplicate and i already check whether any 2 or more elements connect to each other via 1 node( checking by macro). also i cannot upload my model here
Thank you in advance
Hi Tinh,
is it an assembly or just a single component?
Also, does it say that 'failed elements saved'?
Would it be possible for you to share the model via FTP link in my signature?
0 -
Altair Forum User said:
Hi Tinh,
Oh, Pagadala
finally I found the position, it exactly passed my macro without error reported
sometimes I encounter this error because shell elements are connected via only 1 node like this:
so i made a macro (a template) to check it by detecting nodes have more than 2 free-edge elems. It works well
But this time I encounter the error in a covered model so there is no free-edge to be detected, as below image:
actually this is first time i see this error, (in a huge batch mesh model).
This can be found easily by set feature angle 180DEG and mask elements 'by face' but I did not see it before, so I tried adjusting each small area one by one
I hope this function (adjust normal) in newer hm version will show the position of unconnected mesh /emoticons/default_cool.png' alt='B)'>
0 -
Hi Tinh,
Thanks for the update and suggestions. I will let the developers know about this. /emoticons/default_smile.png' alt=':)' srcset='/emoticons/smile@2x.png 2x' width='20' height='20'>
