I am using flexible body to find out the stress generated in the trailing arm during braking. I have encountered this error and don't know what to do. I am facing issue only for this trailing arm. I carried out the same simulations for upper and lower suspension arm and am getting the required results but the simulations is failing for trailing arm. I am attaching the out file and the snips of the same below.
