I would like to extrapolate cycles from a random load history with Rainflow method, using the rainflow command on Compose. However, I do not fully understand how the parameters bin, minrange, maxrange work and affect the rainflow cycle decomposition. Is there an example/tutorial which might be clearer than the help section itself?
Thanks in advance,
Mattia
